Netconfig issue : Impossible to select devices when creating a job
adrienbomble
Hello all,
I am trying to create a netconfig job but i have an issue: I am not able to select devices in the device selector left window. I am seeing all my devices but the box i have to click to select the device appears in light grey and it's not clickable.
Of course when i click on next, LMS says that it's not possible to go further because i didn't select any device. ("CFG0006: No devices selected. Select one or more devices to continue.")
Do you have any idea where the pb is coming from ?
Best Regards,
Adrien
PS: For information, i am running RME 4.2
2 Accepted Solutions
Joe Clarke
You have a package problem. This may be solved by shutting down Daemon Manager copying all of the .zip files from NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/rme to NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs.
If that does not work, you will need to open a TAC service request analyze the problem further.
Assuming nothing else changed, this is most likely a timing issue. After restarting Daemon Manager, you should give the daemons about 30 minutes to fully initialize and settle before trying to access LMS.
Joe Clarke
Thanks for your reply ! I tried what you advised, and i have now a new error when i am accessing netconfig:
CFG0008: Error occured while processing.
Possible Cause: URN_NOT_FOUND : urn "JRM" : Not found !!
Now the two Netconfig windows (device selector and task selector) are blank.
Any idea ? If not, i will try to open a TAC service request.
Best Regards,
Adrien
You were right, i tried too early after restarted the server ; )
Now everything is working fine, and i am now able to select the devices. The problem was really coming from the packages.
Thanks again for your help,
Best Regards,
Adrien
