You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
For an introduction to the new site, click here. If you'd prefer to explore, try our beta test area to get started.
Netconfig issue : Impossible to select devices when creating a job
Hello all,
I am trying to create a netconfig job but i have an issue: I am not able to select devices in the device selector left window. I am seeing all my devices but the box i have to click to select the device appears in light grey and it's not clickable.
Of course when i click on next, LMS says that it's not possible to go further because i didn't select any device. ("CFG0006: No devices selected. Select one or more devices to continue.")
Do you have any idea where the pb is coming from ?
Best Regards,
Adrien
PS: For information, i am running RME 4.2
  • Network Management
2 ACCEPTED SOLUTIONS
Re: Netconfig issue : Impossible to select devices when creating
You have a package problem. This may be solved by shutting down Daemon Manager copying all of the .zip files from NMSROOT/www/classpath/com/cisco/nm/xms/psu/pkgs/rme to NMSROOT/MDC/tomcat/webapps/rme/WEB-INF/lib/pkgs.
If that does not work, you will need to open a TAC service request analyze the problem further.
Assuming nothing else changed, this is most likely a timing issue. After restarting Daemon Manager, you should give the daemons about 30 minutes to fully initialize and settle before trying to access LMS.
Thanks for your reply ! I tried what you advised, and i have now a new error when i am accessing netconfig:
CFG0008: Error occured while processing.
Possible Cause: URN_NOT_FOUND : urn "JRM" : Not found !!
Now the two Netconfig windows (device selector and task selector) are blank.
Any idea ? If not, i will try to open a TAC service request.
Best Regards,
Adrien
You were right, i tried too early after restarted the server ; )
Now everything is working fine, and i am now able to select the devices. The problem was really coming from the packages.
Thanks again for your help,
Best Regards,
Adrien
500
