NetConfig job failing with RME_CDL1031
I have a NetShow job that is failing with this message:
ERROR:RME_CDL1031:Transport  session to device failed Couldnot enter ENABLE mode from USER mode on Device. Couldnot enter ENABLE mode from USER mode on Device.
I have double checked  the credentials in DCR (manually and using the 'check device credentials' option) and its configured properly.
Could you please advice what is wrong?
Amit
1 REPLY
Re: NetConfig job failing with RME_CDL1031
If you are using telnet, the easiest thing to do is get a packet capture of all tcp/23 traffic between the RME server and the device when running the Netshow job.  This will show why RME was unable to enter enable mode.
194
