Community Member
Netconfig Job timeout
How can I increase timeout value for netconfig jobs? In Admin section there is only fetch timeout setting.
Thank you,
Askar
Re: Netconfig Job timeout
The job timeout values are a product of the per-device SNMP, telnet,and TFTP timeouts. If you need to wait longer for devices to complete successfully, you should increase those timeouts depending on the protocol you are using to deploy and fetch config changes.
Community Member
We use SSH for Netconfig jobs and I do not know where to look for SSH Timeouts.
SSH uses the telnet timeout.
150
