Webcast-Catalyst9k
netconfig jobs failing
I am scheduling jobs for automatted vlan change ; the job fails with the following Error - what should be the corrective action
"Command(s) failed on the device TFTP: Failed. Check the credentials are correct or TFTP server is running. Could not synchronize RME archive with Device Config"
Re: netconfig jobs failing
RME is trying to copy the desired config changes to the device using TFTP. The way RME does this is to use the CISCO-CONFIG-COPY-MIB to trigger a TFTP upload. Therefore, you need a valid SNMP read-write credential in DCR for this device. The device also needs to be reachable via TFTP from the RME server. This means UDP port 69 as well as all UDP ports > 5000 need to be open between the device and server.
one more job too failing in another device "Command(s) failed on the device TFTP: Failed on the device. Could not detect protocols running on the device" what should be the corrective action
You need to check what I mentioned before. In order for TFTP to work, you need to have a valid read-write SNMP credential in DCR for these devices, and you need to be permitting the required UDP ports.
161
