Webcast-Catalyst9k
Netconfig. Jobs with parameters.
Good day.
LMS contains pre-defined NetConfigs jobs templates which allow the user to enter the Job parameters in the dialog window (syslog, ntp etc.). Is it possible to create my own template with commands and to let the user enter their parameters in the dialog window?
Thank you.
Re: Netconfig. Jobs with parameters.
You cannot have the user type in text boxes like you can with the pre-defined templates, but you can create your own parameterized Netconfig tasks. This can be done under RME > Config Mgmt > Netconfig > User-defined Tasks. The online help sections http://server/help/rme/fundamentals/netcfg_CrtUserDefTasks.html#wp1072570 and http://server/help/rme/fundamentals/netcfg_ParametTemplates.html go into more details on this.
yes, I've read about parametrized job templates. It seems that parameters for such job can be fetched only from a special xml-file, isn't it?
Correct, the parameter values are stored in XML. But by using this method, these templates are available from the GUI and from cwcli.
205
