Webcast-Catalyst9k
Netflow 3750, 3560
Is there a way to get netflow statistics from 3750 and 3560 switches?
If not, why not, and is there any plans to do such a thing?
Re: Netflow 3750, 3560
No you can't, you'll have to ask Cisco, I doubt it.
HTH and please rate.
Bronze
you cannot use a netflow on 3550,3560 and 3750 devices. This feature is not (and won't be) supported. I think that netflow is not implemented in hardware and CPU is too slow to software generated netflow. You can use a netflow on your upper router (border) or passive probes (see http://www.invea.cz). But you will be able to see only upstream traffic (not a traffic between individual ports).
Kind regards
Jan Nejman
Caligare, Co.
http://www.caligare.com/
614
