Webcast-Catalyst9k
Netflow analyzer
I have 2800,1700 router and 2900,3500 switch. now I want install Netflow analyzer software in my network. so it is possible ?. I know for network analyzer need netflow card in cisco router or switch , it is right ?.
For this what is the configuraton in router ?. and need both configure every switch and router interface.
i nedd clear concept.
pls help me with the proper information.
bilob
Bronze
Re: Netflow analyzer
netflow is supported on the 2800 and 1700 series, but I think that netflow is NOT supported on the 2900 and 3500 series! Netflow cards are available only for bigger routers/switches as Cat4000... Netflow is available only on high-end switches as Cat6500, etc...
Jan
Caligare Co.
http://www.caligare.com
Silver
Netflow is not availaibe on 6500 with Sup720.
Silver
Whoops! ... disregard my previous post. Netflow IS available on Sup720.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/nde.htm#wp1020364
324
