Community Member
Netflow Configuration
Hi Guys,
I am some what new to netflow so any assistance you could give me would be greatly appreciated.
I am running a 6509 Sup 720 - 12.2(18)SXF5. I have setup Fluke Networks NetFlow Tracker as my netflow collector and my configuration is as follows:
interface VlanX
ip address x.x.x.x
no ip redirects
ip route-cache flow
mls netflow sampling
ip flow-export source VlanX
ip flow-export version 9
ip flow-export destination X.X.X.X 2055
I have no data in the Netflow collector but I can see data is being sent. Please see below for an excerpt from the switch.
show ip flow export
Flow export v9 is enabled for main cache
Exporting flows to X.X.X.X (2055)
Exporting using source interface VlanX
Version 9 flow records
3029 flows exported in 484 udp datagrams
0 flows failed due to lack of export packet
0 export packets were sent up to process level
0 export packets were dropped due to no fib
0 export packets were dropped due to adjacency issues
0 export packets were dropped due to fragmentation failures
0 export packets were dropped due to encapsulation fixup failures
0 export packets were dropped enqueuing for the RP
0 export packets were dropped due to IPC rate limiti
Could someone please point me into the right direction?
For the time being, I simply want to turn Netflow on and collect data.
Thank you for your assistance and I will look forward to your response.
Community Member
Re: Netflow Configuration
Hi Chris,
I'm collecting v5 flow records and had to add the following additional configuration to our 6509's:
mls nde sender version 5
mls flow ip interface-full
mls nde interface
mls agingtime long 64
mls agingtime fast 16 0
As far as the agingtime variables, I'd check the Tracker documentation for any specific values.
However, I started seeing data as soon as I added the mls nde sender version.
Hope this helps,
