Community Member
Netflow on 6506-E with Sup 720 and IOS 12.2(18)SXF8
Hi Guys,
I am running many switches with identical hardware, IOS level and Netflow configuration. they are all working, except the last unit configured.
The last units is configured as bellow. Some interfaces are reporting Netflow and some not. The ones configured with netflow are not reporting and some of the interfaces not configured are reporting - not all.
All to the same Netflow Server. I tried pretty much everything but no luck. Clearing the netflow table, deleteing and re-entering netflow configuration.
Any clues?
interface vlan 10
ip route-cache flow
no mls netflow sampling
no ip flow ingress
mls netflow
mls flow ip interface-full
no mls flow ipv6
mls nde sender version 5
mls qos
mls verify ip length minimum
no mls acl tcam share-global
mls cef error action freeze
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination 1.1.1.1 9996
router#show mls netflow table-contention det
Earl in Module 5
Detailed Netflow CAM (TCAM and ICAM) Utilization
TCAM Utilization : 40%
ICAM Utilization : 0%
Netflow TCAM count : 52505
Netflow ICAM count : 0
Netflow Creation Failures : 0
Netflow CAM aliases : 0
router#show ip flow export
Flow export v5 is enabled for main cache
Exporting flows to 1.1.1.1 (9996)
Exporting using source interface Loopback0
Version 5 flow records
1937762 flows exported in 64593 udp datagrams
0 flows failed due to lack of export packet
0 export packets were sent up to process level
0 export packets were dropped due to no fib
0 export packets were dropped due to adjacency issues
0 export packets were dropped due to fragmentation failures
0 export packets were dropped due to encapsulation fixup failures
0 export packets were dropped enqueuing for the RP
0 export packets were dropped due to IPC rate limiting
1 ACCEPTED SOLUTION
Silver
Re: Netflow on 6506-E with Sup 720 and IOS 12.2(18)SXF8
Is ip cef enabled globally?
Then I would add the following to my config. To put the interface and routing information into the NetFlow Exports:
mls nde interface
To break up long flows into roughly 1 minute segments:
mls aging long 64
Export the finished flows in a timely manner.
mls aging normal 32
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SXF/native/configuration/guide/nde.html
Steve
Silver
mls nde interface
mls aging long 64
mls aging normal 32
Steve
Community Member
This is something new, the other 6500 do not need the command bellow for Netflow to work. I added this command and now works perfectly.
mls nde interface
Thanks guys.
Bronze
could you send me part of your netflow configuration?
i.e.:
show running | inc flow
show running | inc mls
Kind regards,
Jan Nejman
Caligare, Co.
http://www.caligare.com/
477
