Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
netflow on 6509
Anyone setup netflow on 6509's? below is my config ... can you verify for me if this configuration is acceptable?
ip flow-cache timeout active 1
ip flow ingress layer2-switched vlan 2,5,6
mls aging long 64
mls aging normal 64
mls netflow interface
mls netflow usage notify 90 120
mls flow ip interface-full
mls nde sender version 5
mls sampling time-based 64
interface Vlan2
ip address x.x.x.1 255.255.255.0
no ip redirects
no ip unreachables
ip directed-broadcast
no ip proxy-arp
ip flow ingress
interface Vlan5
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface Vlan6
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow-export source Vlan2
ip flow-export version 5
ip flow-export destination 172.16.210.77 2055
126
