NetFlow on a Frame Relay - sub interface
I have a frame relay sub interface which is doing frame-relay payload-compression packet-by-packet. Is it possible to configure netflow on this interface. Eventhough I configure on the main netflow entries pertaining to these interfaces are not available in the netflow cache. Please help
Bronze
Re: NetFlow on a Frame Relay - sub interface
To configure NetFlow, first configure the router for IP routing Use the following commands beginning in global configuration mode:
interface type slot/port-adapter/port (Specify the interface, and enter interface configuration mode.)
ip route-cache flow (Enable NetFlow).
For the further configuration of the Frame Relay follow the link :
http://www.cisco.com/en/US/docs/ios/12_0/wan/configuration/guide/wcfrelay.html#wp5157
Thanks for your reply. Other frame relay interfaces which are not doing payload compression are available in the netflow cache entries. The only problematic interfaces are compression interfaces. Is it a limitation?
Blue
Yes, unfortunately NetFlow does not support compression at this point.
447
