Community Member
Netflow showing peak more than the physical bandwidth
Hi there,
I saw netflow reading for peak utilisation is higher higher than the physical bandwidth. How could this be possible? Anyone have this problem before?
Community Member
Re: Netflow showing peak more than the physical bandwidth
Can think of two reasons.
-There is comprssion on the link
-There is some buffering between the link and the netflow process.
Hans
Community Member
I have the same problem.
Can't believe how this is possible.
Community Member
Dit you configure the bandwidth correctly on the interface with the bandwidth command?
Hans
Bronze
which software or tool do you using? I saw some software that badly parse flow information. Try to decrease netflow timeouts. (flows will be more often exported).
see:
router(config)# ip flow-cache timeout active 1
router(config)# ip flow-cache timeout inactive 10
- or -
switch> (enable) set mls agingtime long 64
switch> (enable) set mls agingtime 32
Jan
Caligare Co.
http://www.caligare.com
140
