I have a 837 ADSL router and it is configured to export netflow stats for the Ethernet0 and Dialer1 interfaces. I have enabled ingress & egress flow exporting but the dialer interface is confusing me slightly.
I have the following config (only the relevant bits):
interface Ethernet0
ip flow ingress
ip flow egress
ip route-cache flow
interface Dialer1
ip flow ingress
ip flow egress
ip route-cache flow
ip flow-export source Ethernet0
ip flow-export version 5
ip flow-export destination x.x.x.x 9876
On my Netflow receiver I am receiving stats for 3 interfaces - Ethernet0, Dialer1 and Virtual-Access2. Ethernet0 is working as expected and I am getting ingress and egress statistics. The Dialer1 interface is only exporting Outbound stats and the Virtual-Access2 interface is only exporting Inbound statistics.
I understand the relationship between the Dialer1 and Virtual-Access2 interfaces but I was expecting to receive inbound & outbound stats from the Dialer1 interface as opposed to them being split over the 2 logical interfaces.
I have been through the various commands and can see no way to get ingress & egress stats from the Dialer interface. Can it be done?
I have IOS 12.3(14)T6.
Andy
