Is it enought on Catalyst 4500 enable NetFlow Globally (of course IP routing is enabled from before) with command:
Switch# configure terminal
Switch(config)# ip route-cache flow
or
does it needs enable aggregation configuration
and
what is difference between:
. Autonomous System Configuration
*Destination Prefix Configuration
*Prefix Configuration
*Protocol Port Configuration
*Source Prefix Configuration
regards,
davor
