Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Bronze
netflow
Ripe is asking us to send a graph that shows IP use over a couple of days over all IPs. Is it possible to built such a graph by using netlow ?
Haris
1 REPLY
Hall of Fame Super Silver
Re: netflow
Haris
Netflow can generate the data to support this kind of reporting. But you would need some device and some application to receive the data from Netflow and to generate the report. There are several analysis tools available that generate analysis and reports based on data from Netflow.
Rick
127
