Webcast-Catalyst9k
NetScout nGenius v 1.2 question
We bought nGenius v1.2 alongwith Cisco Works some time ago but never use nGenius. Now I have installed it on Win 2000 "workstation". I want to monitor a network of 6509 switches with CatOS 7.6(10). When I try to add a switch, it does add switch but gives errors. And also I cannot monitor anything.
Any advice please ??
Red
Re: NetScout nGenius v 1.2 question
nGenius 1.2 will not be able to manage this switch, you will need a newer version of nGenius (Cisco no longer ships nGenius)
Thanks.. if thats the case then I'll stop working on ngenius and work on IPM.
111
