07-08-2013 12:39 AM
just a question about exporting netshow job results.
Can be exported to a path in my client PC? I've noticed that I can only select a directory under
NMSROOT/files/rme/NetShow(Where NMSROOT is install directory for CiscoWorks). But could be possible to save it to a remote location in a client PC. This is because network operators cannot access CW server, and I have to send them up the file with the result. It'd be very good to configure CW server to permit save files in local computer where the operator start the web browser.
Thanks in advance.
07-08-2013 12:41 AM
This is not an option now. But you can schedule any custom script to copy files from this location to a common directory for users to access it.
-Thanks
07-08-2013 04:45 AM
Thanks for your response Vinod.
Do you mean scheduling the netshow job or do you mean scheduling any script through a windows task (the server in question is Windows)?
Regards.
