Network Architecture Documentation
mdornsife0212
Does anyone know of any software that can be used to document network architecture as well as switch/router configuration.
jhaegele
I found a program from Kiwi called CatTools. It's pretty slick for the config side of thing. You can write some scripts that can do the same thing, but this is an out of the box solution.
