Community Member
Network Architecture Documentation
Does anyone know of any software that can be used to document network architecture as well as switch/router configuration.
1 REPLY
Community Member
Re: Network Architecture Documentation
I found a program from Kiwi called CatTools. It's pretty slick for the config side of thing. You can write some scripts that can do the same thing, but this is an out of the box solution.
132
