Community Member
Network Assistant (CNA) 5.1 Removal of Neighbors network
I just loaded Cisco Network Assistant on a small network with 8 point to point serial links. Under the communities is my China Lake Community with the correct links. Some how through CDP network Assistant has created a Neighbors community also. I am not able to remove the neighbors community from the Topolgy.
Any input would help Thanks,
1 REPLY
Silver
Re: Network Assistant (CNA) 5.1 Removal of Neighbors network
You need to diasble CDP on those interfaces with the following command,
Hostname(config-if)#no cdp run
202
