Community Member
Network assistant unsupport with C2960PD
Dear All.,
found out the the Cisco network assistant version 5.2 display unsupport product after install the Cisco Catalyst 2960PD-8TT-L,, However, it can be handle the normal setting through this S/E but icon could not be display and show the message with "unsupport product". Is that true the Catalyst 2960PD-8TT-L still not yet to complience with network assistant v.5.2
Tks
jason yeung
1 REPLY
Re: Network assistant unsupported with C2960PD
Here is the supported device table in the release notes and it shows supported:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_network_assistant/version5_0/release/notes/OL12210a.html#wp699844
WS-C2960-24PD-8TT-L
Please download CNA 5.5 and it should show up as being supported.
http://tools.cisco.com/support/downloads/pub/Redirect.x?mdfid=279230132
186
