10-03-2014 10:36 AM
I need to do this with a network with 200 router and switches. Does anybody have suggestion on how to approach this with software?
thanks
10-03-2014 03:13 PM
Sorry, can you please be more descriptive about what you are trying to do?
10-06-2014 07:18 AM
I need to scan a network that has around 200 switches and routers. I also need to come up with recommendations and network visio diagram.
I was looking for suggestions on what software "snmp" that would be best for this and maybe cisco has something that I could use..
t
thank you
10-06-2014 07:35 AM
The Cisco product for this would be Cisco Prime LMS which is provided with purchases of Cisco Prime infrastructure. If you're brand new to network management though I wouldn't recommend taking on its deployment and configuration on your own as it is a pretty complex product and requires its own dedicated server.
10-03-2014 03:43 PM
Please have a look at the response I gave to a similar thread here.
Hopefully it will help you out.
