Network Management: Archive purge not working
Also Posted on - Mar 18, 2008, 6:09am PST
LMS - 2.6
RME - 4.0.6
A brief of logs under rme\jobs\ArchivePurge\1066.x'
(log files: log and log.1-4)
PURGE SETTINGS: ByVersion = true ByAge = false PurgeLabelledFiles = false
number_of_versions 7
info-> handleMultiDeviceExecution,149,Completed executeJob(), updating Results
info-> getNumCyclesToPoll,1018,getNumCyclesToPoll Function Started.
info-> updateMultiDeviceExecResults,781,Awaiting Job results: req Id = 0 Poll time = 5708 min(s)
debug-> updateMultiDeviceExecResults,782,Total No. of devices = 7611 ,numPollCycles 68499 ,Poll Time(Min): 5708
debug-> Stop Job called by Daemon Manager
debug-> CancelJobExecution Started:
info-> 897,Could not get results for 7611 device(s)
debug-> 919,Setting results for Fetch/Purge Job...
debug-> 948,Message : Unable to get results of job execution for device. Retry the job after increasing the job result wait time using the option:Resource Manager Essentials -> Admin -> Config Mgmt -> Archive Mgmt ->Fetch Settings Status : 2
The issue has been there for few months now, I cant remember any change that resulted in this.
>> It would be helpful to see the dcma... by jclarke - Mar 18, 2008, 9:07am PST
Posted by: jclarke - Customer Support Engineer, CISCO SYSTEMS, CCIE - Mar 18, 2008, 9:07am PST
It would be helpful to see the dcmaservice.log with ArchiveMgmt Service debugging enabled.
Re: Network Management: Archive purge not working
Attached dcmaservice.log twice, but I dont see them here!!!!
Make sure once you upload the file, you click the Attach button, then post your comment.
Trying to attach dcmaservice.log again.
There doesn't appear to be anything wrong with the archive. Enable ConfigJob debugging under RME > Admin > System Preferences > Loglevel Settings, then wait for another purge job to run, and post the job log.
158
