Network managment
Hi;
I am evaluating some of the network minotoring tools which will help me to monitor, manage, report genaration and proactivly inform me about any distater.also which will monitor server health and database.....
means it should be enterprise managment solution. If you are having any ,,,,or ur using one which really help you in ur network administration and you really want to share the same wiht me then it will be really great of you. as i am searching for one...right now i am using Solarwinds as monitoring but it wont suffice my requirment......
thanks..
Nil
1 REPLY
Re: Network managment
For my experience, you can use:
1. If your network environtment base on cisco, you can go with CW2K for configuration managemenet & fault management.
2. For other function you may check NetQoS Solution (SA, RA, NV, NPC). I think they have a good solution to see how well your IT infrastructure performance run.
97
