jf
network registrar DHCP scope template question
How does one add more than one option to the Embedded Policy Option Expression in a DHCP Scope Template using Network Registrar 6.2.1?
When I use:
(create-option "routers" (create-ipaddr subnet 1))
(create-option "broadcast-address" bcast-addr)
and click modify, only the routers option shows up after I click modify.
When I use:
create-option
and click modify, it is accepted, but scopes using the template only end up with the router option anyway.
It doesn't accept commas between (), and I can find nothing in the manual about this.
Thanks for any insight you can provide.
1 REPLY
jf
Re: network registrar DHCP scope template question
for anyone wondering about this, here was the answer:
(list
This came from TAC; I didn't find anything in the manuals.
106
