04-14-2010 01:38 PM
I decided to change the display name of switches using Common Services\Device and Credentials\Device Properties\Display Name.
Once I changed it to a name that made sense to me the icon change from green to red. I attempted to change the name back to the default ip address which did change the name but did not change the icon back to green.
Then I deleted it from the topology view, did a discovery, it was found but once again red. Also, did a discovery for the entire network and anything that I change the display name is red and unreachable.
Can /should I delete that data base and do a new discovery.
Also, I can use putty and get to the switches.
Pat
Solved! Go to Solution.
04-16-2010 11:45 PM
Yes, you should be able to change Display Name alone without affecting device manageability in any LMS application.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
04-14-2010 11:01 PM
The display name should not affect the ability for Campus to manage a device. As long as the IP address and/or hostname is filled in with a valid value, Campus should be able to properly manage the device. What version of Campus Manager are you using?
04-15-2010 05:15 AM
1. | CM | 5.0 |
04-15-2010 11:57 PM
If you have Campus 5.0, chances are you are seeing a bug in which Data Collection is no longer happening properly. I highly recommend you upgrade to Campus Manager 5.0.6. To get there, you will first need to move to LMS 3.0.1 which can be downloaded from http://www.cisco.com/cgi-bin/tablebuild.pl/lms301 . Once on 3.0.1, you can get to Campus 5.0.6 from Common Services > Software Center > Software Update.
04-15-2010 05:17 AM
Try putting device names and ip address into windows HOSTS file. Should fix the problem.
04-15-2010 10:54 AM
I'm not clear about host file.
04-15-2010 11:28 PM
The windows HOSTS file is located in your Windows\System32\Drivers\etc . Open it with notepad and in the bottom add your devices' ip addresses and their name EXACTLY as you have entered in CiscoWorks. Then click save and try again.
04-16-2010 11:16 AM
Joe,
I gave you the incorrect Common Services version. The correct version is Campus Manager 5.0.5.
Also, all I had to do was replace the for whatever reason missing snmp3 credentials. However, can I replace the display name without killing anything?
As well thank you once again.
Pat
04-16-2010 11:45 PM
