Community Member
Nexus 7000 Solarwinds Netflow...
Hi folks,
Has anyone had any experience setting up Netflow from the 7010 platform to Solarwinds?
I implemented the following code on both of my cores (VPC/HSRP Redundant Linked Pair) but had the following issues:
1. One of the cores I could see was sending Netflow records every few seconds whereas the other was not doing anything
2. Solarwinds was not seeing any of those records coming in and was showing last update from both devices as "Never"
Note that I have netflow already working as my Riverbed (fairly intelligently) already updates Netflow.
The config I implemented was a follows:
feature netflow
flow exporter CEU-Netflow
description ***Netflow Export to Solarwinds***
destination x.x.x.x
export version 9
transport udp 2055
source vlan10
flow monitor CEU-Monitor
monitor netflow-original
int vlan 131
ip flow monitor CEU-Monitor input
int vlan 132
int vlan 141
int vlan 142
int vlan 151
int vlan 152
Also i was all set to debug this myself but there doesnt seem to be debugging for Netflow that I can see?!?
Any help at all is appreciated guys thanks
Ewan
807
