Community Member
ngenius RTM 1.4 Integeration with ciscoworks 2000
How can we integrate RTM 1.4 with ciscoworks 2000 if both are installed on different servers.
Thanx
1 REPLY
Silver
Re: ngenius RTM 1.4 Integeration with ciscoworks 2000
The RTM 1.4 installation dynamically creates Cisco Management Connection (CMC) files for each available application; these files initially reside in the \rtm\bin folder (on Windows systems) or /rtm/bin (on Solaris systems).
nGeniusS.lf For nGenius Server
nGeniusT.lf For Traffic Monitor
nGeniusK.lf For Packet Analyzer
nGeniusV.lf For Voice Monitor
Before starting the RTM installation, you must manually create the NMSROOT environment variable and reference the root directory where the CiscoWorks2000 software is installed.CiscoWorks2000 uses these files to create menus to launch nGenius Server, Traffic Monitor, Packet Analyzer and Voice Monitor.If CiscoWorks2000 and RTM are installed on different systems, or if nGenius was installed before CiscoWorks2000, you must manually copy the CMC files to the location specified in the CiscoWorks2000 installation.After the CMC files are in place, you must reboot the system for the changes to take effect
110
