NGenius RTM with Cisco Catalyst 4006
Greetings
Can anybody help me how to configure the Catalyst 4006 Switch for nGenius RTM.
Quick reply will be highly appreciable.
Mani
Blue
Re: NGenius RTM with Cisco Catalyst 4006
Is the switch running IOS or CatOS?. In any case, you first need to add the switch to the RTM Server so that it can learn it and then you can use the other RTM features. But without a probe/NAM, you'll only get mini-rmon info in RTM from the switch. See the RTM docs for more details on how to use it: http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/fam_prod/netscout/rel_1_4/index.htm
The Switch is running CatOS. We donot have any probe/NAM so we will use mini-rmon.
Does mini-rom put load on the switch?
Blue
Before you add the switch to RTM, ensure to enable mini-rmon by doing a set snmp rmon enable, unless it is already enabled.
90
