Webcast-Catalyst9k
NME-X-23ES-1G-P is an Unknown Device
Is this device supported? It's an Ethernet Switch Module inside of a 2821. It seems like its managed just fine in CiscoView. But in the DCR it is an unknown device. It seems to not be managed right in RME either. Anyone else have this issue? I'm running LMS 2.6
1 ACCEPTED SOLUTION
Re: NME-X-23ES-1G-P is an Unknown Device
Nevermind. I found that this module will be supported in the upcoming April IDU release.
What is the sysObjectID of this device?
Excellent. Thak you.
209
