No Data on Netflow
I've configured netflow to export data to a correct ip and port number. I doubled and tripled check both sides. And both show the the destination ip and port is ok. SNMP community is doubled check and everything on that side is ok. When I run the sho ip flow ex it comes up with 0's. Any suggestions?
Silver
Re: No Data on Netflow
You don't mention what device(s) or IOS versions you are running, but basically you need enter either of the following commands on each of your L3 interfaces.
ip route-cache flow
or
ip flow {ingress | egress}
http://www.ciscosystems.com/en/US/products/ps6350/products_configuration_guide_book09186a00805b88ed.html
Steve
I did the ip flow ingress egress and enabled the interface itself and everything worked great. thx
Bronze
could you send me your netflow configuration?
i.e.:
show running | inc flow
show running | inc mls
Kind regards,
Jan Nejman
Caligare, Co.
http://www.caligare.com/
126
