no mib snmpv2 in c3845-ipvoicek9-mz.124-12.bin ?
Sorry if my question seem trivial to most of you, but i want a cisco 3845 router to send the coldstart, warmstart, linkup, linkdown traps to a network management server. I found that those traps were in the SNMPV2 MIB using snmp object locator. However when i check with MIB locator which MIBs are included in c3845-ipvoicek9-mz.124-12.bin (the image i will be using), SNMPv2 does not appear.
Does this mean i can not use those traps ? Or are they included somewhere else ?
Thanks for your help.
Nicolas.
Re: no mib snmpv2 in c3845-ipvoicek9-mz.124-12.bin ?
I just checking on my 3845 running the same code and these traps are supported in this code
Here's how you would enable them:
snmp-server enable traps snmp ?
authentication Enable authentication trap
coldstart Enable coldStart trap
linkdown Enable linkDown trap
linkup Enable linkUp trap
warmstart Enable warmStart trap
ok thanks a lot !
i am just wondering though why this mib does not show up in the cisco mib locator with image=c3845-ipvoicek9-mz.124-12.bin (???).
is there another way to be sure that snmpv2 mib is supported inthis image beside the mib locator ?
thanks again for your help.
N.
155
