Webcast-Catalyst9k
NO ping from Rommom prompt
When we are loading IOS of router from rommom prompt using TFTP server.
We are not able to ping to TFTP server.
from rommon prompt.
We tried lots by changing PC , cross cable but it is still not .
Router is not booting as exsisting IOS is corroupt.
What can be the problem ?
Thanx in advance
1 REPLY
Re: NO ping from Rommom prompt
Hi subodh
Which router model you are using up over there ?
Are you able to ping the router ip from the PC ?
Have you checked for the windows firewall which may be enabled there in workstation ?
regds
97
