Webcast-Catalyst9k
No Serial port on Laptop
I dont have serial port on my Laptop , will i be able to connect an ethernet cable with the console port of the cisco ASA 5510 and the network card on my PC  & if yes than what will be the pin out.
1 REPLY
Re: No Serial port on Laptop
You could just purchase a USB to Serial adaptor and use the normal roll over cable.  the adaptor ranges from $10 to $40 US dollars.
410
