NOSServer is not Running on DFM 3.2
Hi all,
We have a CiscoWorks LMS 3.2 with DFM 3.2 on a Windows Server 2008 ServicePack 2. We reregister the NOSServer for another problem but after that process didnt start. Can you help me to reregister de NOSServer properly
Thanks for your help
Rafael Turriago
Re: NOSServer is not Running on DFM 3.2
Post the output of "pdreg -l NOSServer".
Hi Joseph thanks for your help...This is the pdreg command output:
C:\>pdreg -l NOSServer
        Process      = NOSServer
        Path         = C:\PROGRA~1\CSCOpx\bin\cwjava.exe
        Flags        = -server -cp:p MDC\tomcat\webapps\triveni\WEB-INF\lib\log4
j.jar,MDC\tomcat\webapps\triveni\WEB-INF\lib\nos.jar,MDC\tomcat\webapps\triveni\
WEB-INF\lib\ctm.jar,MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-client.jar,MDC\to
mcat\webapps\triveni\WEB-INF\lib\cogs.jar,MDC\tomcat\webapps\triveni\WEB-INF\lib
\ogs-kc1.0.jar,MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-kilnervirtualasa1.0.ja
r,MDC\tomcat\common\lib\activation.jar,MDC\tomcat\common\lib\mail.jar,MDC\tomcat
\webapps\triveni\WEB-INF\lib\tis-client.ja,MDC\tomcat\webapps\triveni\WEB-INF\li
b\pm.jar,lib\classpath\jconn2.jar,lib\classpath\epm-v0-5-0.jar,lib\classpath\ces
ar-v0-5-0b.jar,MDC\tomcat\shared\lib\NATIVE.jar,MDC\tomcat\shared\lib\MICE.jar,M
DC\bin,objects\nos\config,MDC\tomcat\webapps\triveni\WEB-INF\classes,-cw:jre C:\
PROGRA~1\CSCOpx\lib\jre -cw:xrs -Djava.compiler=NONE com.cisco.nm.trx.nos.server
.NOSServer
        Startup      = Started automatically at boot.
        Dependencies = EPMDbEngine EPMServer INVDbEngine PMServer DFMOGSServer
regards
Rafael Turriago
All of the commas here should be semi-colons.  How did you re-register this daemon?
This is the command that I excecuted
C:\PROGRA~1\CSCOpx\bin\pdreg.cmd -r NOSServer -d "EPMDbEngine,EPMServer,INVDbEngine,PMServer,DFMOGSServer" -e C:\PROGRA~1\CSCOpx\bin\cwjava.exe -f "-server -cp:p MDC\tomcat\webapps\triveni\WEB-INF\lib\log4j.jar;MDC\tomcat\webapps\triveni\WEB-NF\lib\nos.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\ctm.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-client.jar;MDC\to
mcat\webapps\triveni\WEB-INF\lib\cogs.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-kc1.0.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\ogs-kilnervirtualasa1.0.jar;MDC\tomcat\common\lib\activation.jar;MDC\tomcat\common\lib\mail.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\tis-client.jar;MDC\tomcat\webapps\triveni\WEB-INF\lib\pm.jar;lib\classpath\jconn2.jar;lib\classpath\epm-v0-5-0.jar;lib\classpath\cesar-v0-5-0b.jar;MDC\tomcat\shared\lib\NATIVE.jar;MDC\tomcat\shared\lib\MICE.jar;MDC\bin,objects\nos\config;MDC\tomcat\webapps\triveni\WEB-INF\classes;-cw:jre^C:\PROGRA~1\CSCOpx\lib\jre^-cw:xrs^-Djava.compiler=NONE com.cisco.nm.trx.nos.server.NOSServer"
Rafael Turriago
This looks right provided this was executed on one line, and there are no stange breaks.  Post the NOSServer.log and the syslog.log.
Hi Joseph
I checked the command excecuted before and I made a mistake. The NOSServer is working now
Thanks four your Help
Rafael Turriago
252
