Highlighted
Community Member
Not Able to add IOS IPS sesor in VMS 2.3
Iam trying me out add the IOS IPS sensor in VMS . However Iam getting the following error message.
" Import of sensor 10.50.1.254 failed.
Error : Error importing configuration files from the sensor - Unable to import sensor config from IOS IPS: Error occurred while configuring crypto commands Error in configuring the crypto trustpoint on the device"
Thanks in advance
rgds
Rajesh
1 REPLY
Silver
Re: Not Able to add IOS IPS sesor in VMS 2.3
From the problem description, I understand you are not able to import your
sensor (running 5.0.5) to IDS-MC (1.2).
Unfortunately, IPS 5.0 is not supported in IDS-MC 1.2.
To manage your IPS 5.0 in VMS, you have to upgrade to IDS-MC 2.1
For the troubleshoot and configuration for the IPS follow the URL :
http://www.cisco.com/en/US/docs/ios/12_4/secure/configuration/guide/sec_ips.html
96
