09-22-2014 01:20 AM
I can see devices in the managed group ,but cannot see devices in fault monitor,its show no device available
09-22-2014 02:54 AM
Balbir,
LMS 4.0 is now obsolete. We recommend to use LMS 4.2.x to have the support.
In LMS 4.x the devices are by default managed by each module like fault monitor. Please share a screenshot where you're expecting and don't see devices.
When was this installed? Was it working ever? You can also try to reset your fault Monitor module by reinitializing the DataBase for Fault.
Check the commands from here:
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
09-22-2014 04:28 AM
09-22-2014 04:43 AM
Devices can be allocated to the following functions in LMS:
•Inventory, Config and Image Management
•Network Topology, Layer 2 Services and User Tracking
•Fault Management
•IPSLA Performance Management
•Device Performance Management
As suggested above by Afroz, make sure you have Fault Management Selected for this module to be active.
For details check user guide :
-Thanks
Vinod
09-22-2014 05:31 AM
Fault management is active .
Balbir
09-22-2014 05:50 AM
Uncheck and Re-check it... wait for sometime and check the status..
Note: doing uncheck and check may remove the notification groups if configured before
Thanks-
Afroz
09-24-2014 05:10 AM
let me know how to re-initialize,what commands to use
09-22-2014 05:57 AM
From command prompt share following output :
pdshow -brief
brcontrol
Also, under Admin > Collection Settings > Fault > Fault Monitoring Device Administration, do you see the devices under Known devices or Questioned/Unknown?
Please share screenshot with expanding the known/questioned categories.
-Thanks
Vinod
09-24-2014 12:42 AM
09-24-2014 04:33 AM
Thanks for the screenshots. They look normal.
I was looking for more details on that last post. Please share following, which seems missing :
"Also, under Admin > Collection Settings > Fault > Fault Monitoring Device Administration, do you see the devices under Known devices orQuestioned/Unknown?
Please share screenshot with expanding the known/questioned categories."
-Thanks
Vinod
09-24-2014 04:42 AM
09-24-2014 04:56 AM
This shows some problem. It seems to have missing details on the screen. Can you try it with other browser like - FF etc.
As you have very less number of devices now, i would recommend to reinitialize the DB, which will be like re-installing only the Fault Management part of LMS.
Doesn't affects your other modules and devices already in LMS.
Ideally you should see screen like this :
If you're not able to see other options, its better to start over.
-Thanks
Vinod
09-24-2014 05:21 AM
09-24-2014 06:38 AM
Good to know it shows now. Are the devices under known devices?
If devices appear in Known devices, it should be fine.
-Thanks
Vinod
09-22-2014 04:37 AM
Since LMS 4.0 was not working .i have done the reinstallation.i am able to see the topology view and see devices as managed.
Balbir sIngh
