Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Not able to view logs in syslog report beyond 4/5 days
We have CIsco Prime LMS 4.2.4 installed on Windows. When I am trying to generate Syslog reports from following path...
reports>Faults and events>Syslog>
for period of more that week it shows logs for last 4/5 days. I have tried all possible options available like monthly weekly or schedulling of report. But no luck. Current size of log file is around 1.5Gb. Can some one help me to sort out this problem.
Ganpat Gawas.
Hi ,
Did you check the actual syslog.log ..
Open the syslog.log using Notepad++ or editplus and check the syslogs date and time there.
Thanks-
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks for your response Afroz. I have already checked the Syslog file & confirmed that it has logs of last one month.
175
