Community Member
Not getting alerts of 10gig interface on 6509
We are using 6509 switch and problem is that SNMP is working fine for all other interfaces but not getting any link up down alerts for 10 gig interfaces.
Can somebody suggest on this.
Re: Not getting alerts of 10gig interface on 6509
What version of IOS is running on this switch?  On what module type are these ports?  How are they configured?  How is SNMP configured on this switch?  Are you not receiving SNMP linkUp/linkDown traps?  Are you receiving syslog messages for link up/down events?
Community Member
Hi Joseph,
s72033-advipservicesk9_wan-mz.122-18.SXF14.bin is the IOS and SNMP traps are enabled. We are able to see the log entries in switch but not getting
interface up/down alerts through NNM. IF-MIB is used by NNM and its working for all other interfaces except ten gig module interface.
Post the configuration for these 10 Gbps interfaces.
Community Member
interface TenGigabitEthernet1/1
description us1-b36mra1r6-cr3 ten1/4
switchport
switchport trunk allowed vlan 1,2,16,18,80,82,84,88,128,130,268,276,280,282
switchport trunk allowed vlan add 307,322,327,334,522,523,526-529,531-535,594
switchport trunk allowed vlan add 595,597,598
switchport mode trunk
switchport nonegotiate
no ip address
logging event link-status
end
Try configuring:
snmp trap link-status
Under these interfaces.
267
