Community Member
Not Reachable past Core switch?
This is a fresh install of LMS 3.1/CM5.0. For some reason I can't get CM to reach past my Core switch. Any idea why?
I tried using SNMPv3 authentication, but for some reason couldn't get that to work at all. I enabled an SNMPv2c community string and was able to get this far.
Thanks for any help you can provide.
Type OID IP Address Host Name Neighbors Status
1. 172.20.5.48 172.20.5.48 UnReachable
2. 172.20.5.52 172.20.5.52 UnReachable
3. 172.20.5.220 172.20.5.220 UnReachable
4. 172.20.5.25 172.20.5.25 UnReachable
5. 172.20.5.30 172.20.5.30 UnReachable
6. 172.20.5.36 172.20.5.36 UnReachable
7. 172.20.5.72 172.20.5.72 UnReachable
8. 172.20.5.24 172.20.5.24 UnReachable
9. 172.20.5.71 172.20.5.71 UnReachable
10. 172.20.5.74 172.20.5.74 UnReachable
11. C6509-IOS .1.3.6.1.4.1.9.1.283 172.20.5.1 172.20.5.1 172.20.5.220, 172.20.5.71, 172.20.5.69, 172.20.5.20, 172.20.5.23, 172.20.5.24, 172.20.5.25, 172.20.5.10, 172.20.5.15, 172.20.5.29, 172.20.5.30, 172.20.5.32, 172.20.5.52, 172.20.5.48, 172.20.5.223, 172.20.5.72, 172.20.5.36, 172.20.5.74, 172.20.5.40, 172.20.5.62, 172.20.5.54 Reachable
12. 172.20.5.69 172.20.5.69 UnReachable
13. 172.20.5.40 172.20.5.40 UnReachable
14. 172.20.5.32 172.20.5.32 UnReachable
15. 172.20.5.223 172.20.5.223 UnReachable
16. 172.20.5.10 172.20.5.10 UnReachable
17. 172.20.5.23 172.20.5.23 UnReachable
18. 172.20.5.20 172.20.5.20 UnReachable
19. 172.20.5.62 172.20.5.62 UnReachable
20. 172.20.5.54 172.20.5.54 UnReachable
1 ACCEPTED SOLUTION
Re: Not Reachable past Core switch?
Unreachable implies the SNMP community strings in your Discovery settings are not correct. Make sure you don't have the v3 strings still configured with an overlapping range. That is, if you have SNMPv2c strings configured for *.*.*.* and you also have v3 credentials for *.*.*.*, only the v3 credentials will be tried.
If you still can't figure it out, start a sniffer trace filtering on UDP port 161 to one of these unreachable devices. Start a new Discovery, and see what credentials are being used to access the device.
Community Member
Jclarke, that was it. For some reason the wildcard did not work the first time, but did the second time around.
365
