Blue
Not seeing certain traffic in NetFlow cache
Could anyone explain why I do not see the pretty constant traffic between a remote IP camera and the backend in NetFlow cache, but I do see the icmp traffic once I ping the camera?
Bronze
Re: Not seeing certain traffic in NetFlow cache
1. Where are you checking netflow traffic? On the collector or on the router via show ip cache)
2. Did you enable netflow on all interfaces? If you have 6500/7600 also enable mls nde ...
Kind regards,
Jan Nejman
Caligare, Co.
http://www.caligare.com/
Blue
I'm looking both on the router and on the collector (GUI). On the router, I'm using "show ip cache verbose flow" and "show mls netflow ip [source/destination]", which show the icmp traffic as soon as I start pinging.
NetFlow is enabled on all interfaces, and in both software and hardware cache.
Bronze
If I clearly understand, you are able to see icmp pings on your router but not in collector GUI. Is it correct? Could you send me output of the:
show runn | inc mls
show runn | inc flow
Thank you,
Jan Nejman
Caligare, Co.
Blue
Jan,
You misunderstood. I see icmp pings (generated by myself) on both the router and the collector GUI. The problem is I don't see the alleged video traffic on either the router or the collector.
show runn | inc mls
mls aging fast threshold 64
mls aging long 128
mls aging normal 64
mls flow ip interface-full
no mls flow ipv6
mls nde sender version 5
show runn | incl flow
ip flow-cache timeout inactive 64
ip flow-cache timeout active 3
no mls flow ipv6
ip route-cache flow
(repeat for each interface)...
ip route-cache flow
ip flow-export source Loopback0
ip flow-export version 5
ip flow-export destination xx.xx.xx.xx 9###
144
