Nothing other than seed device
As I execute Layer 2 View with in Campus Manager\Visualization\Topology Services..
All I see this the seed device and none of the other switches.
Dell Power Edge 2850
Intell Xeon 3.0 2.99, 2.00 GB Ram
MS Server 2003 W/sp 3
LMS 3.0.1:
CM 5.0
DFM 3.0
HUM 1.0
IPM 4.0
RME 4.1
Thanks for the help ahead of time.
PAt
Re: Nothing other than seed device
You may be running into a bug which was not fixed until CM 5.0.3 (meaning you will need to upgrade to LMS 3.0.1 then apply the 5.0.3 service pack). However, before that, make sure CDP is properly configured on your devices, and the show cdp neighbor command properly reflects the directly connected neighbors on the seed devices which are showing up on the map.
Yes, CDP reflects the directly connected devices. I will up grade, and return with the results.
94
