NW devices backup
I am looking for a free tool which can backup switches, routers, FW's and other cisco devices. currently i am using kiwi cat tools free version which has a limitation of 20 devices?
Sridhar
  • Network Management
1 REPLY
You can try to use Cisco's
You can try to use Cisco's Free tool - Cisco Network Assistant.
Cisco Network Assistant simplifies wired and wireless network management for networks up to 80 devices with its intuitive GUI and a task-based menu. Cisco Network Assistant is free and is optimized to apply common services across Cisco switches, routers, wireless controllers, and access points.
Cisco Network Assistant facilitates:
  • Network discovery and convenient display in a topology map
  • Configuration management of Cisco products fitting small and medium businesses
  • Single-click Telnet or access to device manager
  • Front panel view of devices, clusters and stacks
  • Inventory reports and health monitoring
  • Troubleshooting of common network issues
  • Event notification of network errors and alarm thresholds
  • Drag-and-drop Software upgrades saves time in maintaining your network
  • Direct access to lifecycle information using Cisco Active Advisor
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
60
