OID for active calls
I'm running a WS-X6608-E1 blade as voice gateway and want to monitor the amount of active calls. To do this manually, I'm using the command "show port voice active", but is there a possibility to query this via snmp?
Re: OID for active calls
Have a look at the following link to see if it gives the details you are looking for:
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a008048349c.shtml
Thanks, that would be exactly what I have been looking for, but this MIB does not seem to be supported by the WS-X6608-E1 blade, which must be run under CatOS. As workaround, I'll code a small script using the cli.
Silver
I like small scripts. A lot of people can be replaced by them :)
147
