OID power supply
Hi all,
I use an 1720 router and I need to know if there are an a possibility to check the power supply.
The electrical network is not stable and I want to know if there are possibility to count the number of cut?
Re: OID power supply
No, the 1720 does not offer SNMP management of the power supply.
Thank you for this reply, I must replace my router, by a 871?
It's possible to have power managment information on 871?
No, the 871 does not offer power management via SNMP. You can see the list of platforms with CISCO-ENVMON-MIB support at http://tools.cisco.com/ITDIT/MIBS/AdvancedSearch?MibSel=4497&SUBMIT1=Submit . The various platforms will have different levels of support. It depends on hardware as to whether or not certain aspects of the ENVMON-MIB are supported.
582
