Community Member
OID string for opitcal monitoring on IE-3000 switch
I posted this in the Optical forum, and it was suggested that I post it in this forum, as well.
I'm looking for the OID string on a IE-3000 switch to give me the results for the optical Tx and Rx power as shown in the "show interface transceiver" command (this is the output i ran directely from the IE-3000 switch, BTW):
                                 Optical   Optical
           Temperature  Voltage  Tx Power  Rx Power
Port       (Celsius)    (Volts)  (dBm)     (dBm)
Gi1/1        30.1       3.29      -6.1      -7.3
The OID I am using on our 6509 switch for Rx power is .1.3.6.1.4.1.9.9.91.1.1.1.1.4.xxx (where xxx is the ifindex number), but I can't seem to find anything similar for it on the IE3000.  The closest I have found are the following, but those appear to be just descriptor tags:
.1.3.6.1.2.1.47.1.1.1.1.2.1029 (tx)
.1.3.6.1.2.1.47.1.1.1.1.2.1030 (rx)
Thanks for any help!
Kim
348
