Community Member
OID to obtain VLAN to Switchport Assignments
I am trying to use SNMP to obtain VLAN to Switchport Assignments. Does anyone know the OID for this?
1 ACCEPTED SOLUTION
Re: OID to obtain VLAN to Switchport Assignments
For access ports, you can use the vmMembershipTable from the CISCO-VLAN-MEMBERSHIP-MIB to get this information. The table is indexed by ifIndex, and the vmVlan object will tell you the vlan for that port.
1 REPLY
147
