Blue
/opt/CSCOpx/bin/PSUCli.sh usage
So I downloaded
Cat6000.RME40.v2-0.zip and placed it in /var/temp/patch, but how do I install it with PSUCli.sh? I've tried with Cat6000.RME40.v2-0.zip as is, or unzipped:
/opt/CSCOpx/bin/PSUCli.sh -p rme -install -src /var/temp/patch/ Cat6000
It always comes back with
Services might be restarted, as a result of install operation
Would you like to continue ? ( Press y or n )
y
Proceeding with install..
Loaded psu.properties..
INFO: Installing for rme
Locking the package repository...
got all packages Repository
Checking Dependencies...
Warning: Cat6000(2.0):Consistency check failed for base package SharedDcmaCatOS
Warning: Cat6000(2.0):Consistency check failed for base package SharedInventoryCatSwitch
Warning: Cat6000(2.0):Consistency check failed for base package SharedSwimCAT
There are no Packages to be installed
Released the Lock...
then, when unzipped
/opt/CSCOpx/bin/PSUCli.sh -p rme -install -src /var/temp/patch/com Cat6000
1 ACCEPTED SOLUTION
Re: /opt/CSCOpx/bin/PSUCli.sh usage
You MUST NEVER unzip device packages. The problem with installing the device package above is that it has dependencies which are not satisfied. It requires a later version of SharedDcmaCatOS, SharedInventoryCatSwitch, and SharedSwimCAT. You need to download those updates, or otherwise install them on your server before you can install the new Cat6000 package.
1 REPLY
187
