OSPFv3 SNMP MIB not reporting anything
I have a 3945 router connected to an IPv6 network.  It is running the Cisco IOS 15.2-4.M3 software version. It has one active OSPFv3 neighbor.
My problem is that I need to get OSPFv3 status via SNMP.  However when I walk the SNMP mib at 1.3.6.1.3 I get replies for 1.3.6.1.3.963* and 1.3.6.1.3.118.*.  I don't get anything for the OSPFv3 mib at 1.3.6.1.3.102.  Can someone tell me how to get OSPFv3 status via SNMP?
According to the Cisco Mib locator this software should support the OSPFv3 MIB.
Everyone's tags (1)
Hi , Try doing the SNMP Walk
Hi ,
Try doing the SNMP Walk to the following OIDs.
Make sure to use the initial dot before the OID number as shown below:
 .1.3.6.1.3.102
 .1.3.6.1.2.1.191
Thanks-
Afroz
***Ratings Encourages Contributors ***
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
including the initial dot
including the initial dot before the OID does not solve this problem:
C:\>snmpwalk -v 2c -c public 197.16.18.1 .1.3.6.1.3.102
SNMPv2-SMI::experimental.102 = No Such Object available on this agent at this OID
If I expand the walk to .1.3.6.1.3.* I do get data from the router:
iso.3.6.1.3.61.1.1.1.0 = INTEGER: 60
iso.3.6.1.3.61.1.1.12.1.2.1 = IpAddress: 0.0.0.0
iso.3.6.1.3.61.1.1.12.1.3.1 = Timeticks: (0) 0:00:00.00
iso.3.6.1.3.61.1.1.12.1.4.1 = INTEGER: 0
iso.3.6.1.3.61.1.1.12.1.5.1 = INTEGER: 2
iso.3.6.1.3.90.1.1.1.0 = Counter32: 0
iso.3.6.1.3.90.1.1.2.0 = INTEGER: 500
iso.3.6.1.3.90.1.1.3.0 = INTEGER: 5
iso.3.6.1.3.90.1.1.4.0 = INTEGER: 2
iso.3.6.1.3.90.1.1.5.0 = INTEGER: 2
iso.3.6.1.3.90.1.1.6.0 = Counter32: 0
iso.3.6.1.3.90.1.2.1.0 = INTEGER: 3000
iso.3.6.1.3.90.1.2.2.0 = INTEGER: 0
iso.3.6.1.3.90.1.3.2.0 = STRING: "T"
iso.3.6.1.3.90.1.4.1.0 = INTEGER: 1000
iso.3.6.1.3.90.1.4.2.0 = INTEGER: 10000
iso.3.6.1.3.90.1.4.3.0 = INTEGER: 30
iso.3.6.1.3.90.1.4.4.0 = INTEGER: 150
iso.3.6.1.3.90.1.4.5.0 = INTEGER: 150
iso.3.6.1.3.90.1.4.6.0 = INTEGER: 300
iso.3.6.1.3.90.1.5.1.0 = ""
iso.3.6.1.3.90.1.5.2.0 = INTEGER: 2427
iso.3.6.1.3.90.1.5.3.0 = INTEGER: 1
iso.3.6.1.3.90.1.5.4.0 = Timeticks: (0) 0:00:00.00
iso.3.6.1.3.92.1.1.1.0 = INTEGER: 2
iso.3.6.1.3.92.1.1.2.0 = Timeticks: (36000) 0:06:00.00
iso.3.6.1.3.92.1.1.3.0 = Gauge32: 0
iso.3.6.1.3.92.1.1.9.0 = INTEGER: 30
iso.3.6.1.3.95.1.1.0 = Gauge32: 0
iso.3.6.1.3.95.1.2.0 = Gauge32: 0
iso.3.6.1.3.95.1.3.0 = Hex-STRING: 00
iso.3.6.1.3.95.1.4.0 = Gauge32: 65535
iso.3.6.1.3.95.2.1.0 = INTEGER: 0
iso.3.6.1.3.95.2.3.0 = Gauge32: 0
iso.3.6.1.3.95.2.5.0 = Gauge32: 0
iso.3.6.1.3.95.2.10.0 = INTEGER: 2
iso.3.6.1.3.96.1.1.1.2.0 = Gauge32: 0
iso.3.6.1.3.96.1.1.1.3.0 = Gauge32: 0
iso.3.6.1.3.96.1.1.1.4.0 = Gauge32: 0
iso.3.6.1.3.96.1.1.1.5.0 = Gauge32: 0
iso.3.6.1.3.96.1.1.1.6.0 = INTEGER: 0
iso.3.6.1.3.96.1.1.1.7.0 = INTEGER: 0
iso.3.6.1.3.96.1.1.1.8.0 = INTEGER: 0
iso.3.6.1.3.96.1.1.1.9.0 = INTEGER: 0
iso.3.6.1.3.96.1.1.1.10.0 = Hex-STRING: 80
iso.3.6.1.3.96.1.1.1.11.0 = INTEGER: 2
iso.3.6.1.3.96.1.2.1.1.0 = Gauge32: 0
iso.3.6.1.3.96.1.2.1.2.0 = Counter32: 0
iso.3.6.1.3.96.1.2.1.3.0 = Counter32: 0
iso.3.6.1.3.96.1.2.1.4.0 = Counter32: 0
iso.3.6.1.3.96.1.2.1.5.0 = Gauge32: 0
iso.3.6.1.3.96.1.2.1.6.0 = Counter32: 0
iso.3.6.1.3.96.1.2.1.7.0 = Counter32: 0
iso.3.6.1.3.96.1.2.1.8.0 = Counter32: 0
iso.3.6.1.3.96.1.5.0 = INTEGER: 0
iso.3.6.1.3.96.1.8.0 = INTEGER: 0
iso.3.6.1.3.96.1.10.0 = INTEGER: 6
iso.3.6.1.3.96.1.11.0 = INTEGER: 0
iso.3.6.1.3.96.1.13.0 = INTEGER: 0
iso.3.6.1.3.96.1.15.0 = INTEGER: 2
iso.3.6.1.3.96.1.16.0 = INTEGER: 2
iso.3.6.1.3.96.1.17.0 = INTEGER: 2
iso.3.6.1.3.118.1.1.1.0 = Gauge32: 0
iso.3.6.1.3.118.1.1.2.0 = Gauge32: 0
iso.3.6.1.3.118.1.1.3.0 = Gauge32: 0
iso.3.6.1.3.118.1.1.4.0 = INTEGER: 2
iso.3.6.1.3.118.1.1.5.0 = Gauge32: 0
Note that 1.3.6.1.3.102 is skipped.  Thus I don't think it is the method by which I am querying the router.  Any other ideas?
205
